My tablo is working perfectly. My question is the only thing I miss from cable, and that is the ability to program my recorder to automatically record the same program every week. Can I do that with my tablo.
If you have a subscription you can use the guide to set repeating recordings. Either all or only new episode. Then use the settings page to set the no dup option if needed.
Or use the manual recording option for repeat recordings.
