HELP!! Playoff games are starting and I was not aware that we would need to record these!! I am unable to get any live TV to record. I have tried rebooting as well as rescanning channels.
Do you have a USB HDD plugged into your Tablo?
Do you have an active guide subscription?
In the Live TV grid…
Move the pointer to highlight the show you want to record, not the channel.
If using a remote control, press the OK button, not the Play button.
Rec button should display.
Click on Rec, and it’ll start recording:
Click on Info, and you’ll have more recording options:
yes!
