Recorded shows have incorrect info
I set my 4th gen Tablo to record all episodes of Saturday Nigh Live. Most of the older ones it indicates was recorded on the TBD channel, which is a CW network subchannel on local OTA antenna. When go to watch one it’s actually some QVC type shopping program. This has happened on the last 5 SNL’s I tied to watch.
What’s up with that?
Your guide data may be wrong. It happens. If you watch that channel live, does the programming match what is in the guide?
I just tried watching that same channel live and it is not showing the program listed, still playing the Shop LC show. Guide was update 9 hours ago.
Well, your Tablo is recording what is being broadcast… You program guide is just lying about what is on.
If you haven’t already, try changing your ZIP code to one that is different but nearby. You may get the right data for that channel. Unless, you don’t think there is anything of value for you on that channel, in which case you could just remove it from your selected channels.
@Keith15335 - if you do change your ZIP Code, I think you’ll also need to rescan your channels.
