I just received my Tablo Dual HDMI. I am transitioning from a Channel Master DVR+
Here is my Tablo:
- the latest firmware 2.2.31 (2033219) as of Dec 2.
- Western Digital Purple WD82PURZ 8TB hard disk in an OWC Mercury Elite Pro USB3 case.
- I have a Stacker antenna on the roof (from dennysantennaservice).
- the Tablo connects to my Denon 3600 AV receiver via HDMI.
- Tablo audio is set to Passthrough (the HDMI to my Receiver).
- ethernet connection (Tablo WiFi is turned OFF).
- my antenna is pointed at the Walnut Grove, California, antenna farm (near Sacramento).
The installation process was straight forward and the Tablo came up quickly. The setup process was fine, but it saw that new firmware was available and downloaded it. I had to re-turn off WiFi after this firmware update. Note sure if that is typical, or just due to the update during initialization.
The initial 24-hour guide population process took 8 minutes. The rest of the 14-day guide was populated in the background. I assume there is initial overhead for this first acquisition since 8 minutes seems really slow for simple text info.
The Tablo found 58 channels. Of those, I selected 34 channels to go into the Guide. See my channel comparison comments below about DVR+ vs. Tablo. The bottom line is that both units found the same channel portfolio and signal strengths seem comparable. A viewing test of some of the weaker Tablo channels demonstrated that they were indeed watchable so to first order the Tablo receiver seems comparable to the DVR+ receiver.
The Tablo CH+ remote’s channel-to-channel flip time is 4-7 seconds and feels painfully slow. The DVR+ time using CH+ on its remote control is 2-3 seconds.
My lowest RF channel is RF9 (6.1, PBS) which corresponds to the 2nd longest elements on my antenna. On the DVR+ recordings, this channel is sometimes blocky/pixelated due to signal issues. In watching the Tablo for a bit on this channel, there is some pixelation.
The Guide scrolling of the Tablo is very responsive, but it doesn’t pre-populate the entire Guide. It only populates when you get to a blank portion of the Guide.
Conclusions:
At this point, I am happy with my Tablo Dual HDMI. It seems like a lateral move from my DVR+ and is functional. Compared to other products that I considered (Tivo Edge, Amazon Recast, etc.) I especially like that the Tablo has an HDMI connector and outputs the full-resolution broadcast stream. And I like that it works with my 8TB hard disk. Colors are vibrant and the picture is sharp. The sound is good but I wish that the Tablo would map broadcast stereo into 5.1 (or the 7.1 that I have). It sounds hollow just in stereo.
Action items for the Tablo developers:
How do I disable the Screensaver? There isn’t a choice for OFF. There should be.
The 14-day guide needs a Search function. As-is, trying to find shows is a treasure hunt.
Need to add the “name contains” function that the DVR+ has for specifying recordings. This is extremely useful.
the Guide should pre-populate the entire 14-day window with text. Not wait to populate until someone scrolls to a blank portion of the Guide.
Here is a comparison of the Channel Master DVR+ (135R) receiver with the Tablo Dual HDMI (2.2.31) receiver with my antenna and distance from the broadcast antenna farm. The DVR+ quotes signal strength (0-100) and signal quality (0-100). The Tablo quotes number of dots (1 to 5).
Each channel is shown that the units auto-scanned. The DVR+ was measured from 4:00 to 4:40pm (it took awhile to write down all of the numbers). The Tablo was measured from 5:20 to 5:35pm. Same RF cable, antenna, etc. since I moved the various cables from the DVR+ to the Tablo then went through its initial start-up sequence.
Both units found the same channels and the signal levels seem to correlate.
DVR+ Tablo Dual HDMI
3.1 100 100 3-1 *****
3.2 100 100 3-2 *****
6.1 100 52 6-1 *****
6.2 100 59 6-2 *****
6.3 100 62 6-3 *****
6.4 100 62 6-4 *****
10.1 100 59 10-1 *****
10.2 100 59 10-2 *****
10.3 100 58 10-3 *****
10.4 100 59 10-4 *****
13.1 100 100 13-1 *****
13.2 100 100 13-2 *****
13.3 100 100 13-3 *****
19.1 100 100 19-1 *****
19.2 100 100 19-2 *****
19.3 100 100 19-3 *****
19.4 100 100 19-4 *****
23.1 94 100 23-1 *****
24.1 81 79 24-1 *****
24.2 82 79 24-2 *****
24.3 80 83 24-3 *****
29.1 100 62 29-1 *****
29.2 100 59 29-2 *****
29.3 100 57 29-3 *****
29.4 100 62 29-4 *****
29.5 100 65 29-5 *****
29.6 100 62 29-6 *****
30.1 71 38 30-1 ***
30.2 71 41 30-2 ***
30.3 72 39 30-3 ***
31.1 100 100 31-1 *****
31.2 100 100 31-2 *****
31.3 100 100 31-3 *****
31.4 100 100 31-4 *****
31.5 100 100 31-5 *****
33.2 100 73 33-2 *****
34.1 100 49 34-1 ***
34.2 100 50 34-2 ***
38.1 77 0 38-1 *
38.2 80 0 38-2 *
38.3 81 0 38-3 *
38.4 84 0 38-4 *
38.5 85 0 38-5 *
40.1 100 100 40-1 *****
40.2 100 100 40-2 *****
40.3 100 100 40-3 *****
40.4 100 100 40-4 *****
51.1 81 61 51-1 ***
51.2 80 62 51-2 ***
51.3 81 55 51-3 ***
51.4 77 58 51-4 ***
58.1 100 100 58-1 *****
58.2 100 100 58-2 *****
58.3 100 100 58-3 *****
64.1 100 100 64-1 *****
64.2 100 100 64-2 *****
64.3 100 100 64-3 *****
64.4 100 100 64-4 *****
Note that the various 38.x and 38-x channels had a black screen on both the DVR+ and the Tablo. There is no channel 33.1 nor 33-1.
The one that stands out are the 6.x channels. I feel that the DVR+ metric is more appropriate than the Tablo metric (based on my previous viewing experiences). This channel can sometimes be problematic for me and Tablo’s 5-stars doesn’t jive with DVR+'s more appropriate signal quality metric of 52 to 62.
Update at 8:16pm: channel 6.1 has broken up on the Tablo and it suspends viewing and presents a popup box. I keep hitting Resume and it keeps presenting the popup box. This popup box is useless… The DVR+ was always more graceful and would just keep trying. So originally when the Tablo scanned, channel 6.1 was 5 green dots, now it presents a Weak Signal popup box that requires continual button pressing.
Thanks,
Scott
