http s://community.tablotv.com/t/factory-reset-not-working/32847
Hi thank you for the reply.
my problem is that I need to remove 26 blue tabs of the same show on my recordings list. There are no recordings on any of them. I purchased a 4th Gen. And all
Is well. Thanks to all.
