R.I.P. Zap2It is gone
Zap2It has shut down. Apparently because the service was being abused.
Website takes you to NewsNation now.
Name dropping a bit, maybe people could look at https://wiki.xmltv.org/index.php/Main_Page
(for those that build things needing an EPG)
We will have to make do with the Gracenote version TV Listings- Find Local TV Listings and Watch Full Episodes
It looks exactly the same as Zap2it. Even the error I complained about 4 times is still there. No place to complain anymore though. Except the guide is 3 hours off.
what are you guys using these for? I wish there was a way in the Tablo Gen 4 to customize the guide channel mapping. It often is mapping my stations to the wrong thing in the guide. Those of you who have used Plex, JellyFin or HdHomeRun know that there you can customize the mapping. @TabloTV can you provide a way to customize the channel guide to channel line up mapping?
I primarily use it to see what is on at night.
Allows me to set up the DVR to record an item, that I might possible miss by turning TV on after it started or finished.
Good example from this week:
I had not seen any ads for the season premier of The Cleaning Lady on FOX.
Saw it in the online guide and set the DVR.
