I am trying to perform a Factory Reset on my QUAD.
The instructions say:
- Remove the hard drive (if attached) from your Tablo DUAL HDMI or QUAD HDMI
- Remove the power adapter from the Tablo DUAL HDMI or QUAD HDMI
- Insert a small pin through the hole located on the bottom of the Tablo DUAL HDMI or QUAD HDMI
- Insert power adapter to the Tablo DUAL HDMI or QUAD HDMI while holding the pin in place
- Wait for “erasing” message on screen, release pin
I do not understand what screen they are referring to.
I am doing the factory reset because I completely lost all connectivity.
Nilex
2
Is your device a QUAD HDMI or the network-connected QUAD? When you say connectivity do you mean network connectivity?
If you have a network-connected Tablo the instructions are different and are found here…
system
Closed
3
