Provide more information about your internet setup.
Do you have only an ISP modem? Or do you have an ISP modem and separate personal router?
This is important to know. Because many new ISP modems are not only modems, they are usually combo modem and routers. So if you have a separate router, then you likely have two DHCP servers running (called double NAT). This prevents port forwarding from working properly.
