Hiya tech folks!
I am about to install a DB8e antenna (with a VHF retrofit kit) in my attic along with a 50’ run of RG6 cable feeding a Tablo-Quad as well as a TV directly.
Just today, I came upon an Antronix MRA2-11 (2-output) Advanced Residential Amplifier, powered by it’s own 12VDC 200mA transformer.
My question: is this amp (even) appropriate for OTA use?
Brief specs:
52-1002MHz Fwd (+11dB)
5-42MHz Return (-4dB)
Here is a link to a much more techy spec sheet, if need be:
(http://www.antronix.net/files//DS-1041-AR_MRA.pdf)
Thanks for any help in advance!
