Programming not available - again
@TabloTV @TabloSupport
Well, it’s happening again.
Portland Ore guide starts losing programming ~1AM on April 8.
Plus PBS consistently has wrong data for shows and different times.
Could we get this fixed so I don’t have to look every morning to make sure what I want to record is recorded at the proper time?
Give up and move on. I turn my gen 4 off - too many problems. I have plenty of legacy units.
And then I was stupid and installed 2.2.58 on a little used legacy unit with no intention of using the gen 4 apps. Same bugs as the gen 4 firmware. Except they don’t seem to want to roll the release back to 2.2.42 as they promised.
You can still use the Legacy app even if you are running 2.2.58. It should work exactly like it used to. Did you still have the subscription for the 14 day guide? Then that agin should still work as normal when using the legacy app and ignore the 4th gen app.
I installed it a week ago and have 3 open bug tickets. And only use the legacy Roku app. I have only recorded 1 MLB game.
I have a lifetime subscription.
I ran a guide update from the legacy app in my browser and it didn’t change a thing. April 8 is the drop off point
