The last two episodes of Big Brother (Sunday and Wednesday night) were only partially recorded. Sunday’s was 45 minutes and last night only recorded 5. No storms in the area and other shows have recorded normally, but to be honest, we’re not recording much this time of year. I viewed the logs for these two episodes and noticed:
[TS_RECV] The firmware has a fatal error. Driver must be reloaded to restart the operation.
[CLOSE] The firmware has a fatal error. Driver must be reloaded to restart the operation.
[DEALLOC_FB] The firmware has a fatal error. Driver must be reloaded to restart the operation.
send system turn off command
at the bottom of just these two.
Could this be a firmware issue with 2.2.10? Hard drive starting to fail? Maybe heat related?
What logs are you looking at, the ones on the Tablo itself?
How are you doing that?
I’d love to do that, too.
@Radojevic, In a browser, goto {ip of Tablo} :18080/pvr. select a rec_id, click on log/ and download the rec_tcvid file.
