Problem with "playback failed" solved
When I went to my channel guide and clicked on “watch Live” I got a “Playback failed” error.
I called Tablo and got no solution. I looked at my Library and decided that it looked Overfull.
I deleted everything in the Library so it was empty. I was then able to watch Live channels.
Sounds like maybe the disk was full, and Live TV didn’t have space to handle FF & REW.
Just a thought…
If that is the case, Tablo should reserve space for that purpose that can’t be written to when you record a show.
I thought it left 2G per “tuner” – so there should have been plenty unless every show was set to save all.
It does, but not if you have auto-delete disabled.
If that’s not the case @drummerkak let us know.
