Here’s the deal… All my network gear is in my basement. It’s where my Verizon FiOS comes in, it’s where my rack of equipment is, AV, Network, everything. Basements aren’t known for their strong RF signals though (at least for TV reception anyhow!
) So I have my tablo up 2 flights of stairs in the guest bedroom with it’s power Leaf antenna basically attached to the window. I get decent signal although my area isn’t known for having tons of channels, nor super strong signals. For the record, i’ve never tried putting the tablo in my basement but I just suspect it would be awful for reception.
Going 2 flights up, Wi-Fi is spotty in that area of the house so I have a 2.4Ghz and 5Ghz “repeater” for some devices like the kid’s room Amazon Fire TV box and for when he wants to watch something on his iPad – but I really didn’t want the tablo to connect via a WiFi extender…
My first powerline AV box was a Linksys PLS400 or some such nonsense. The link would drop and I’d have to reboot the AC boxes to get it to re-establish. Not a very fun thing to do, especially when you’re in the middle of a show and the stream degrades to nothing.
I did some EXTENSIVE research and found that the ZyXEL PLA series had excellent reviews (maybe a little costly) and a lot of people used for streaming media extension type situations like this. I just pulled up a Tablo stream and looked at the ZyXEL config tool and it looks like 78Mbps down and 51Mbps up from the remote AC adapter.
However every so often I do think I need to reboot the power adapters. The stream going from my Tablo to my Amazon Fire TV box gets garbled or just freezes… sometimes it takes forever to start up a stream… and I reboot all the devices – AC Powerline Adapters and Tablo usually – sometimes I go so far as to reboot the Amazon Fire TV. It’s usually when i’m pressed for time and just want to get it back up and running quickly. I will, however, start to only reboot one device at a time and see what works to solve the problem. But most of the time it works fine… just that 5% of the time when I want to rip everything out!!!
So my question is this… are there better Powerline Ethernet Adapters that people have used for this application that I should consider? OR is there a technology that I should try instead? Or a design change to what I have??
Basically… i’m looking for any recommendations that might help stabilize this!!!
Thank you!
