Port scan shows SSH port (22) open
what is the root password to login into via SSH?
I don’t think I can use the same credentials as the app, but I might be wrong, probably password login is not allowed because I get the following message: “Permission denied (publickey,password)” when I try with the app user/pass
Thanks
That error message says an SSH key is required to connect. This port isn’t publically accessible and can be ignored. Unsure if the Android App uses SSH to communicate with the device directly, using a SSH key.
Thank you
