Port Forwarding on eero
I have first generation Tablo and when I changed internet provider I have an eero 6+ router and cannot get port forwarding to work so I can get Tablo Connect. Anyone else have this problem or has a way to fix it.
I don’t have it but you may have to download the user guide to see if you can figure out how to make it work. This is assuming that the ISP doesn’t have their own customization done to the router that would prevent you from doing port forwarding.
