Port Forwarding for Tablo Connect - driving me crazy
Hi,
I’ve been trying to set up port forwarding for Tablo Connect for months.
Here’s what Tablo is telling me to do:
And here’s what I’ve done on my Verizon FIOS router:
I think I have the Tablo address correct, and I think I have all the port numbers correct. Tablo doesn’t like it, though, and still asks me to reconfigure manually. Can someone please help?
Thank you!
@MarkPekala - Pop a note over to our support team. They’re happy to help out: http://bit.ly/TabloTVHelp
try to reverse the number and see if it work. TCP 8887 -> 21101…
When you figure it out be sure to also give your Tablo a static IP or else when the DHCP lease changes your router could potentially give your Tablo a new IP address which would break your settings.
