I am a new owner of a Tablo, I am trying to do a port forwarding to a Belkin router about 3 years old, it need to do a manual port forwarding, but I haven’t been able to figure it out. When I contacted Belkin support, they weren’t too helpful. Model # F9K1105V2. Has anyone been able to do this?
If I can’t do port forwarding, what routers are you using that is easy to do connect remotely (Tablo connect) ?
It looks straight forward on the link below.
What is the make and model of your ISP modem? Is it just a modem? Or does it have a built in router function too?
Login to the router home page, then click on Advanced Settings, then look under Firewall and click on “Port Forwarding”.
I purchased a newer Belkin (AC1200) router to replace an older Belkin. The new one was fast and worked great but I could never get it to cooperate with Tablo. I even worked with Tablo support. The older one was just too old and started to struggle with everything. I finally replaced them with a Netgear R6400 and it’s been smooth sailing since.
If you are trying to manually setup port forwarding make sure UPnP is turned off. If it has UPnP.
