Since the latest Tablo firmware and software updates. Tablo has not been picking up my tv stations I use to get.
Open a support ticket and get Tablo to check your logs.
Firmware .28 works perfectly here. You on a dual tuner or quad tuner?
I have a quad tuner. My ticket number is 5342.
I have been struggling with the same problem. I was a beta tester and everything worked fine with the initial firmware update for the beta test then after they pushed out a second update I found that 95% of the time I could no longer tune to one particular set of channels. (20-1, 20-2, & 20-3 ABC, this is also the closest station to me at only 13 miles).
It has happened 4 times since the latest update, neither reboot or unplug/plug fixes the problem.
Downgrading back to the pre-beta firmware did not fix my problem so it isn’t the firmware and I presume is just a coincidence that I lost the channel at the time of the update…
At this time I am out of ideas and have emailed the network tv station to see if they have any thought.
