If I start watching a program in the middle of it’s recording can I start watching from the beginning? I saw a post to the affirmative from 2014 but I wanted to check if it is the same today on the new units . Thanks.
Yes.
And there are a couple of ways to do it.
- Go to Recordings and select that recording. Even though it is recording, it will start at the beginning.
- Go to the live tv grid and select that channel. Since it has been tuned since the recording began, you can rewind to the beginning.
