Recently, I have started to get regular pixelating artifacts. It happens on all channels. I am using an iPad Air and Apple TV 4 via AirPlay. Netflix and other streaming apps are working 100%.
If I connect the antenna directly to the TV tuner, no problem. I have rescanned all channels on both the TV and Tablo, and all are showing excellent signal strength. I have tried a different wifi network, and the problem is still there.
I have been away for the past 8 weeks, so not sure when the problem started. As well I upgraded to the new Apple TV. So it could be a Tablo software upgrade that cause the issue or a compatibility problem with the new Apple TV. Any other users having this issue?
I got this product so I could record the news each night. It is presently no use to me if I cannot fix this issue.
