Can anyone get the 4th gen Tablo App to work on the PC.
I open the app and it asks me to rescan. I do and it flashes and spins for 1/2 a second then askes me to rescan.
I have tried with wify by un plugging the wire. and I can find the tablo server. and it connects. but cant go then nothing.
Never this less I want to use the wire on the TV. that works find. and the Phone apps work fine.
Same issue here… The only way for me to make it work is install an android emulator called BLUESTACKS. Then install Tablo to it, and it becomes like an icon on your desktop like a virtual machine. It works wonderfully, and it can also record the screen too… Although I prefer OBD for screen recording. I know it is not perfect, but at least there is a way or maybe a work around.
