I was watching a show on the laptop, paused it to continue watching via Roku and the graphic with the blue bar in Roku shows the show being watched almost halfway but when I selected it to watch I did not get “continue watching from” option, only the play option. I tried it anyway but nope, it started from the beginning. I went back to the laptop to see where I left off but it started from the beginning there too. @tablosupport I thought this ability was there across all platforms?
When you paused it on your laptop, did you leave it at that point, or did you close out of that show (close Tablo or use arrow to leave it)?
There’s no choice but to leave it open with the web app. There’s no exit. You pause it and then “back” out.
I don’t understand when folks say “exit” as there’s no exit to Tablo.
So, any device using web app - you can pause and nothing else, nothing more. Exiting a browser closes the browser, the Tablo is still sitting waiting for the next command which never comes.
(maybe this will help some)
I decided to watch something on my Tablo…
1. Live TV - I watch, then I pause, I back out (leave the watch screen)… If I return to this same channel and if I did not force a tuner off of that channel… I may be able to pick up where I left off (more on this later), or at least find myself back to the original temorarily (limited) recorded stream. How would I force it off? If the Tablo, due to channel surfing or its need to start a recorded program or somebody else using a tuner… whatever the case is where the Tablo needs to switch that tuner to doing something else…
2. Fully Recorded - No tuners involved. I can watch, and hopefull back out, and ideally resume where I left off. I’m pretty sure this is the functionality that “should work” today.
3. Inflight Recording - There’s an active tuner being used to record the inflight show. I have no idea if resume works in this scenario or not, but in theory it could (vs. Live TV, where it could partially work, but not always work because the recorded stuff is transient and you may be beyond the limit of what it keeps on disk). So, ideally, you can make the whole resume marker thing work in this case, but can’t say if it does or not.
Most people just want #2 to work I believe, but again, I think it could work just fine in case #3 as well. Case #1, well… it can’t always work… it just can’t… so not sure if it should try lest people complain, etc…
Tablo is an always “on” device. It’s kind of like the Internet. Just because you got out of the browser doesn’t mean the Internet stopped.
You exit the Web app by clicking on the left arrow in the top-left corner of the viewer area. Please note that the arrow is not visible when the browser window is maximized.
@ShadowsPapaYou exit the Web app by clicking on the left arrow in the top-left corner of the viewer area. Please note that the arrow is not visible when the browser window is maximized.
That is exactly what I mean. It appears that once you click on that arrow, the save point is “registered” to the Tablo so that it will resume on any other device. Just pausing the show isn’t enough.
@snowcat, problem is with the web app you have to hit back to get to that page and it still does not save where you were. I just -retested just to be sure.
That doesn’t exist on a phone.
The left arrow is in the upper right on my computer, non-existent on the phone.
In my Chrome browser under Windows, the left arrow is in the upper left corner and the down arrow is in the upper right corner. I didn’t check on the phone but I’m not surprised it wouldn’t exist.
On my Android phone, I just use Android’s go back button. That has the same functionality, and it exits the recording.
@snowcat yes, that is what I am talking about. on our phones it is not saving the last watched position
@jestep @shadowspapa @sgnadeau Agreed I see the same ways to leave a show but I found different behavior when pausing/leaving and trying to resume playback.
It apparently works correctly with Android Lollipop but not KitKat.
@snowcat, yep that is what it seems. Problem is, it worked pre-Christmas…
My phone is 4.4.2 whatever that is. I do numbers far better than names that show no sequence of build.
I too have 4.4.2 which I think is KitKat. And the only buttons I see are the 20 sec RW skip and 30 sec FF skip and both work in either landscape or portrait mode for me. I suppose the thinking is that with touch screens there isn’t a need for the regular FF/RW buttons although I don’t have the iPad nearby to check it it’s same there and whether the iPad has the back/drop down arrows.
