Outdoor antenna to my tablo 4 tuner with coaxial cable
Ok my question is can i connect my outdoor antenna directly to my tablo device.
That’s what I did with my ancient 2-Tuner (first gen I think). The Tablo is inside, not outside. They are not designed to be left outside. You do want to run the cable from the antenna into the house.
I do and it works great in my rural area.
Yes, just connect your antenna cable coming from your antenna to the Tablo rather than your TV and your ready to go.
Yes. That’s what I have done.
I have a Televes powered antenna. The power block has 2 coax outputs. One to the Tablo and one directly to the tv. I have a legacy HDMI connected 2 tuner Tablo.
