How do you get Live TV while viewing the Tablo channel guide? I only get a static screen that says “Live TV” and shows the current time.
Is your antenna connected to the Tablo? Did you do a channel scan? What are you using to try to view live TV? (Roku?, Fire Stick?, web app?..)
The video works normally on all channels. Scanning did not solve the problem. its an issue whether I view the guide on my nvidia box or a pc.
