I bought a Windows 10 tablet (ASUS T100) which I’m in love with…but when I try to access live TV with my Tablo using the latest Google Chrome browser, it just stutters too much.
I’ve read it’s because Google uses its own Pepper flash. I’ve tried using the system flash in its place, but the controls are gone.
So, what are our options? Here’s what I found:
Chrome --> too jerky
Microsoft Edge --> was working beautifully, but now it’s broken and won’t connect
Safari for Windows --> could not connect
Firefox --> could not connect
Opera --> haven’t tried it yet
IE --> Works great, fully functional EXCEPT I cannot go full screen. This is what I’m currently using.
I’d be curious to know what other Windows 10 tablet users utilize to get smooth live tv playback. Especially sports. Thanks
Have you tried Google Chrome Canary? Seems like it’s faster than the regular chrome. Also, you may be able to fix your Edge browser… mine works perfectly on my Win 10 laptop.
I have four PCs that run Windows 10.
On two of them Tablo works like a champ in Edge; on the other two all I get is “Connection could not be established, retrying…” Cannot figure out why it won’t connect, works fine in Chrome on the same machines.
Also, I haven’t checked to see if this will work as I haven’t had to do it in Windows 10 yet, but the Control Panel is still showing the “Internet Options” feature. If you open that, and go to the “Advanced” tab, there is a “Reset” button down near the bottom.
Ikahhan, I looked at the link but it is the same procedure I have already tried with no success. The only thing different was to kill the MicrosoftEdge.exe process so I did that as well but it made no difference. The Control Panel “Internet Options” reset refers to Internet Explorer not Edge but I tried it also but again saw no difference in results.
