Option to enable remote access disappeared
Up until today, I had a check box available under settings that would allow me to enable remote connection. The entire option has disappeared making it impossible to turn this feature on. Why did it disappear?
Do you have a guide data subscription?
no, is that require for remote access?
Yes - the list of features that are available with/without a subscription are listed here:
