Onn keeps giving unable to decode error when playing back recordings.
When the same recording is played back on another device no issues.
Yes, I have Uninstaller and reinstalled the tablo app several times.
Yes I have restarted the router
Yes, I have rebooted the tablo several times
I was not getting this issue with an earlier version of the tablo app. Is there anywhere I can download an earlier version of the andriod tv tablo app?(can only find the mobile app).
I can recommend you go to apkpure.com where you can download the Tablo apks all the way back to Sept 2023. Their apks are dependable but I still always run virustotal scans on any apk I download. Its very easy to sideload an apk to your ONN. I have dozens of apks that have been downloaded and work perfectly on the ONN. Do you know the procedures for sideloading apk’s. If not come back here and either I or someone else here can help you.
Of course I have all the needed software available and I have done it literally over a hundred times on many devices and networks. I could download the apk, verify it, transfer it to the ONN and then install it using Xplorer (or similar) in well under a minute. Very very easy after a small learning curve.
