It seems there is a new problem every day now. Last night when we tried to watch in 2 different rooms the second connection would always go back to the menu screen after a minute or 2. Then I would occasionally get a message that a tuner could not be found. Still getting message that previous equipment can not be found every time.
Do you have a 2 Tuner or a 4 tuner?
How many shows were being recorded?
Were you watching Live TV or a Recording?
2 Tuner, no recordings, attempting to watch a live TV program on each
And just to be clear both connections are using the same WiFi the Tablo is on???
Also could recordings have just finished recently? A tuner is required to generate thumbnails.
Yes, same WiFi. Not sure about previous recording but by the time I gave up it would have been at least 30 minutes as I missed the entire show I was trying to watch.
@dmgray55 - Can you pop us a note so we can investigate why you’re having these issues? We’d like to get this patched up for you: http://bit.ly/1w8BrBw
Is your hard drive working? The Tablo will only use a single tuner if there is not a hard drive.
Good point thanks
