ac0x
October 5, 2018, 1:26am
1
Hello Group
I have one channel and only one channel that gives me a consistent error of “Could not play live stream”. WDCI Chicago 57.1 (RF 30.1). Channel scan shows it with a strength of 5 green dots but an “unknown” format. I am able to decode the signal when directly connected to a Vizio TV set.
Any ideas would be appreciated. Thanks.
zippy
October 5, 2018, 3:14am
2
It use to be that tablo required that PSIP metadata exist for the channel and that the minimum required fields were properly filled out.
Most TV’s can display a minor amount of PSIP data when OTA antenna is directly connected.
Other then that you would have to ask support exactly what the message means especially since WDCI is a low powered translator.
ac0x
October 5, 2018, 4:44am
3
Thanks. Incomplete PSIP metadata sounds like the most likely culprit considering the strength of the signal and the fact it’s only one channel.
zippy
October 5, 2018, 4:54am
4
Open a ticket and let support give you an answer.
But this thread babbles about PSIP.
Unfortunately yes.
The engineers at the station are supposed to include this data in the stream but apparently there’s an equipment manufacturer sending out a software update and telling the engineering teams that a field within that software doesn’t need to be filled out… But it does and if the data is missing, badness ensues for anyone using the digital information to tune/understand that channel.
We’re trying to figure out which equipment manufacturer it is so we can prevent this from happ…
ac0x
October 9, 2018, 1:17am
5
Ok now the Tablo can decode the channel - even though channel scan still can’t display the format it’s in. Go figure. Gift horses and stuff I guess
