For better or worse my new Tablo 2-tuner behaves the same as my old 2-tuner Tablo ( Poor receiver sensitivity, Tablo reboots itself when signal is very weak ). So, Tablo, tell us about all the hardware improvements you made on the SPVR2-02-NA Tablo. Thanks
Details of your antenna system pls.
I don’t think they made any changes to the tuner hardware.
That depends on which model.
The DUAL LITE does indeed have a new tuner/demod:
http://www.maxlinear.com/maxlinear-and-pixelworks-selected-by-nuvyyo-for-tablo-dual-lite-ota-dvr/
That being said, if your reception is weak you’re not going to have a great experience with any OTA DVR.
The OP did specify the SPVR2-02-NA, which is not the LITE. Were there any changes in that model?
Sorry! Monday requires moar coffee.
We did NOT use a new tuner/demod for the DUAL 64 as the one used for the LITE was not available at the time of the design phase for the DUAL 64.
