Odd occurrence last night (LPW)
Any links for these products?
Thanks!
I used this for the USB adapter: http://www.amazon.com/aLLreliĀ®-Adapter-LIFETIME-WARRANTY-Samsung/dp/B00J631SU8/ref=sr_1_fkmr0_2?ie=UTF8&qid=1449600803&sr=8-2-fkmr0&keywords=ust+otg+nexus+player
I think this is the one he used for the Ethernet adapter but he can correct me if I’m wrong: http://www.amazon.com/Plugable-Ethernet-Network-Adapter-Chromebook/dp/B00484IEJS/ref=sr_1_fkmr0_1?ie=UTF8&qid=1449600860&sr=8-1-fkmr0&keywords=Plugable+USB+2+to+Ethernet+LAN+Adapter+nexus+player
Looks like this Ethernet adapter would work as well and is a little cheaper at $10: http://www.amazon.com/Cable-MattersĀ®-Ethernet-Network-Adapter/dp/B00ET4KHJ2/ref=sr_1_3?ie=UTF8&qid=1449600993&sr=8-3&keywords=ethernet+usb+adapter
Your link to Amazon for the Plugable brand adapter I used is correct. I chose it because the manufacturer website specifically says it is tested with the Nexus player. And it did work perfectly.
I had a Trendnet adapter and also tried it with the Nexus briefly, and it also worked properly.
I was initially worried that there might be some driver required or compatibility issue, but these adapters apparently do not require a driver installation when used with The Nexus player.
