Couple of other thoughts… is your PC on Wi-Fi? Can you try on Ethernet?
Also, I’ve seen where extensions or add-ons can interfere with a browser’s ability to properly display sites, especially ad blockers. You could try disabling them.
I’m also having problems with my tablotv.com. I get endless syncing with no connection. Has support solved your problem? I’m awaiting response from my last email.
Hello. I’ve had Tablo for nearly 2 years. Half the time it does not work. I get internet from AT&T. Is the ATT tall black box what you refer to as a “router”? ( am completely tech-challenged.) I’ve seen you promoting Ethernet over Wi-fi. Those of these lights are green on my router(?), but the wi-fi light flickers a bit. Right now my Tablo box blue LED is flashing rapidly and the tablo hard drive is steady. What does this mean? What can I do? What can you do? I haven’t been able to watch TV for 2 week!I
PV1000, try switching to InPrivate browsing in Chrome and see if it connects. If it does, run Ccleaner and clean up the regedit and see if that clears things. It did for me.
karenevans, do you have your tablo connected to your router (tall black box)? Your lights sound fine. What device do you use to connect to the Tablo?
First thing I would try is: unplug the router, then unplug the Tablo, wait 5 mins - then plug in Router and give it a few mins to come on line, then plug in Tablo and see if it comes on and works. Pls send results.
I did all you said and the blue LED on the Tablo box is just blinking 1 X second. I’ve pushed buttons, pulled plugs, and reconnected plugs to the point that I don’t realy know what goes into what anymore. Only one thing stays true: that blasted bllue LED will NOT settle into a steady blue light so I can watch my TV (it’s been 2 weeks.)
I didn’t get a note with “next steps.” It’s been nearly 3 weeks with no TV. You told me you were sending me a new hard drive (like I even know what that means) to replace malfunctioning one.
I’m very sad and upset. Why aren’t you helping me? At this point, I’m reading or hearing about all of the final episodes of my favorite shows. This sucks. PLEASE RESPOND.
@karenevans That’s odd; we’ve been sending over messages since Monday - the last one with regards to your replacement was sent over on Tuesday. I’ll PM you a copy!
Well, Tim, by now you know I can be a complete asshat. Sorry for last night’s grumpiness. And you DID send me a message on Monday – I just didn’t see it among my inbox debris.
SO . . . I got the Tablo box today. I can’t fathom any of your or David’s instructions. I AM educated, really, but my degree is an MFA in Theatre Performance (the only need I had for my computer was to type my thesis.) i haven’t done anything other than to open the box, because I KNOW I’ll screw it up. Can I call you (or vice-versa) to walk me through this? I know that’s a big ask, but if I have to do it alone, I might as well use this thing as a door-stop.
Hi Karen - we’re here for another half hour today, please feel free to give us a call: 1-844-TABLOTV (822-5688). Or, you can respond to Tim’s email directly, and the two of you can set up a time for tomorrow
