No storage connected
Legacy System was working fine until Fri 10/18/24 at around 3am. I tried to reset the tablo and the blue light blinked for sever minutes. I reset the router and the light became solid. Now it appears all is working except the external disk drive. A message comes back the there is no storage connected. I have two other tablos connected and they appear to be working fine. The one that is not working is a tablo quad with no memory.
What should I do next
Now the tablo has shut itself off.
First guess would be a failing/failed power supply.
You were correct. Tablo is working again. Thanks
