If I plug my antenna into a TV I get channel 35-1 (WB network) with good picture and sound.
Same antenna cable plugged into the tablo and I do not get sound when viewing live tv or on recordings from that channel. I was reading a similar thread on the forums with someone else has this issue, and a rescan fixed the problem for him. I have tried multiple channel scans and the result is always the same. No audio on the channel when connected to tablo-4 tuner box. (Like I said, the channel audio works find connected directly to my TV).
Anyone have any solutions for this problem?
Thanks
Paul
