I read an article about remote access and it should be available on my tablo but I do not see the option. Article says not available on 4th gen but I have a Dual Lite DVR and have had it for a number or years so dont believe that is 4th gen.
For anyone with pre-4th gen, go to your device using your browser, go to Settings and see if there is a Tablo Connect section. Easiest way to know if you have that feature.
