No OTA Channelson IOS Tablo app
The title says it all, using the IOS IPad app cannot load ABC, NBC, CBS, FOX, PBS, COX/Warner. I can however access all the other channels that show up in the scan. (ION, etc). The Tablo Roku app is a different story and works as expected, all scanned channels working. The only error messages I get are “failed to open” or “cannot decode” .
Looking for guidance…
Try enabling the “Audio compatibility mode” setting.
I’m pretty sure that Audio Compatibility Mode is a Roku only setting. It should have no impact on iOS.
Hi @Mbibb ,
It sounds like you may have run a channel scan already. If you haven’t try it on your iOS device.
Either way, the key is to select save after running the scan so the data can push over to your device.
Thanks for the advice, I rescanned and this time pressed the save button and it is now working🙏
