No Guide data for CICA TVO in Toronto
I am able to receive Ch 19.1 TVO in Toronto and watch live TV but there is no guide data available, just a blank line for that channel in the live TV section. I’ve tried several different postal code locations but none of them have come up with the missing data. It’s worked fine in the past but not now. Not sure exactly when it went MIA. I have a Legacy Tablo and have also tried the 4th Gen app but it is also missing the data for that channel.
Never mind, the guide data is now back!
Now it’s gone again! Nothing but a blank line across the guide for this station.
Hi @AceConrad, we checked the channel on our backend, it seems something may have gotten stuck. Try checking again. You may need to close and reopen the app you’re using to see any updates.
Thanks, it’s back!
The Guide data is gone again!
Apologies, we’re working through some backend processes with stuck channels. This one should be good again now. Thanks for bearing with us!
It’s back! Thanks
Things must be “stuck” again! Guide data for CICADT 19.1 in Toronto is missing. Shows up on the Gracenote web site but is blank in both the Legacy and 4th Gen apps.
The same goes for CICO-DT-28, Kitchener, Virtual channel 22, RF channel 28 (UHF).
@Cliqueofone
The guide data for CICO-DT-28, Kitchener should be resolved.
@AceConrad, would you DM us your SID? If you do we’ll share it with support and they’ll take a look.
Just sent the SID this morning and then checked the Guide. It was already fixed.
That’s good to hear @AceConrad,
If it happens again though, please let us know.
Well, that’s the fourth time it’s happened in the last three months so it seems probable that it will come back!
Till next time!
