No double fastforward on Samsung tv
If you want to watch a recorded program on Samsung tv there is no option like double or triple fast-forward like roku or fire stick.
Dont know if it is a feature lacking by programmer for Samsung tv.
One suggestion i have, in case you want to watch a 2 hour program and want to fast forward it to a point 1 hour later, go to your phone and fast-forward it there and pause. Then you can come to your tv and it will start the program from there
Hi @stonysqash ,
On the Samsung Remote you should be able to hold Fast-Forward or Rewind, to make both go faster.
Not sure what you are stating here Tablo tv support. Please read my message. You cannot do a double or triple fastforward from Samsung Tv remote. You have to keep on hitting the same key to move fast forward or rewind.
On the bottom of the samsung tv remote there is a double or triple fastforward / rewind which does not work.
Roku and fire stick has no issues
This is a programmer/ developer issue for samsung tv.
Yes, please fix your app on Samsung TVs so we can FF and Rew at variable speeds instead of holding the button for 5 minutes.
