The support of Tablotv will send me another.
Is the connector a 2.1mm x 10mm?
No clue I cut the end off of the broken power brick and soldered it onto the end of the recycled USB/sata adapter power supply. My warranty has expired so I didn’t have anything to lose.
None of the power bricks I had in my pile of left over e-stuff had a connector that would fit the tablo.
I finally found a 12v / 3A power source that I had at home. I did exactly the same thing and I finally got back my device Tablo. My device works well. Eureka! Thank’s and happy new year from St.Lambert, Quebec.
I would like to purchase a standby replacement power supply for my TABLO. As cheap as they are and considering the existing investment in the system overall I believe such a purchase would be advisable to maintain operation.
To Tablo support: Can you make the power supply available for separate purchase or advise an Internet mail-order source?
THANKS!
Now @TabloSupport will see this.
I’ll pass this along to the team and let you know!
