This is going to be wierd. I had a newer model tuner that was working fine. Been using tablo for years. All my channels came in fine. Suddenly nothing would come in. No live tv. I tested channels and it said “no channels found in my area”. Even a weak signal will find something. I tried tightening the coax and ended up breaking the connector. So I disconnected that tuner and reconnected an older one I had that works fine. I also replaced the antennae and I replaced the wire going from the tuner to the antenna.
Hooked it all up and got it working great. All the channels came in…recording great. It worked about a week until today.
Now with a different tuner, a different wire and a brand new antennae that’s been working great for a week and guess what. I can’t get live tv and I tested and it said “no channels found in my area” (again).
I rebooted my Shield android device and reloaded the app. Still no channels found.
It sounds like a software issue now. Incapable with Shield?
All the hardware is different from the first “no channels found” and now again getting “no channels found” again.
The only thing the 2 situations where I got a “no channels found” have in common is the android Nvidia shield and the app. Otherwise my Nvidea Shield works perfectly.
added: I just read someone suggested maybe interference. Maybe a HAM operator interfering in my neighborhood? Any other ideas.
