An update is now available for the newest Tablo Roku Channel for 4th generation Tablo devices.
If you’ve already got the latest Tablo channel installed, and your ROKU is set to automatic updates, you should see version 0.7.400 very soon. You can also manually update the channel by going to the app settings and selecting “Check for updates”.
Here’s what you can expect:
Tablo Roku Channel (4th Gen) Update (v. 0.7.400)
Adds improved connection logic to reduce instances of app not being able to find Tablo
Fix to ensure deleted episodes are correctly reflected
Fix to ensure firmware update progress is shown correctly and app reconnects automatically when done
Many interface improvements across multiple screens
Go to Shows and list by channels. The channel list shows up in the left vertical ribbon. go down to carbon tv or possibly others. No shows appear in the right panel but the empty place holders do. use the right d pad over to one item and click okay.
You get the blue screen and the spinning wheel of death. The right d pad does nothing. The first back button click appears to do nothing. The second back button click the left vertical tab appear. The focus is on channels. the right panel still has all the empty place holders for carbon tv.
You might also get some one to fix the guide. If you look at Movies for “the film Dectective” movie Bloodlust. The banner says it runs from 12:41AM-2:04AM which seems normal.
But below the description it says it is 1 hour. gen 4 will record for 1 hour. This isn’t the first movie that’s been chopped.
There must be a reason why when you record a fast channel and then go to all recordongs the actual thumbnail doesn’t contain the “real” recordin time and not just a copy of the start/end times from the description.
Of course I can’t think of a reason. It not like there isn’t tons of real estate available. Of course you can play the reording, do the math, and see that it matches the description.
There must also be a reason that a recorded FAST channel allows FF but there are no thumbnails - it is almost 2024, not 2014
