I only caught this because I have 2 Tivo Stream 4k’s running Android TV. I updated the first one and noticed the guide didn’t look right, so I took before and after pictures of the second one.
By the way, the Disconnect option on the app is way down on the bottom of the Settings menu, which makes it a pain to switch between two Tablos. Is there another way to switch between Tablos, or could the Disconnect option be moved to the side menu like on the phone and PC apps?
For the fire tv stick app this is a change they made to the preview app just before they rolled it to replace the regular app. Probably 8-12 months ago. I got tired of bitching about it. Of course you should also discover that if you disconnect(in the setting page) when you re-enter any of your tablos you will be in the settings page - nice.
Not quite sure I agree. It’s a visual issue, and you can click on the show title to view the full title text. Seems like a small follow-up update to resolve this issue would be sufficient.
This problem just started in the last few days and only happens on Fire TV sticks, not on Roku devices. Seems like when I enable 14 day live TV grid that triggers the problem, program names get cut off in the TV live grid. Disable the 14 day feature and the program names appear correctly. I have two fire TV sticks and they both have this issue.
Yep, same here. I don’t use my Fire Stick much and had the 14 day grid off so I probably wouldn’t have noticed this. Mine is the latest version 4K Stick.
The only way I’ve found to force an update on Android TV is to go to the Google Play Store and search for Tablo as if you’re doing an install. It’ll do an update since it’s already installed.
I did an update today and the guide is fixed. I’d still like to see Disconnect moved to the main menu, but I see this has been suggested by several users for about a year now, so it’s either complicated or not a priority.
