I just got an idea and talked to David. Since EPG provider seems to be having problems getting data for 54-2 and 54-3 in Austin, I found the channels they are on in San Antonio. So I told them 78758 channel 17.4 is 54.3 and 41.3 is 54.2. Same time zones even so you would think they could simply copy them. 54.3 is LAFF and 54.2 is GRIT. Sure would make it easier to record.
@TabloSupport I told David the wrong zip code to copy and called back. 78758 is mine and 78148 is the one to copy from.
Any update? Itโs been a week since they started broadcasting and I called last Friday afterjoon.
@TabloTV 54-2 and 54-3 still missing guide data David told me they were added. Whatโs going on? For what it is worth Zap2it.com is also missing them. I just sent them a message today.
For what it is worth, I asked in another Austin forum and no EPG on TiVo either fgor 54-2 and 54-3
