New (4th Gen) Tablo - Won't Find Network channels [SOLVED]
I just bought the newest 4th Gen Tablo (4-tuner) and it won’t find my local network channels (ABC, CBS, NBC, FOX, CW). I didn’t change anything other than to unplug my old Tablo (that picked up everything with my omni-directional antenna mounted on my roof at 35’). When I plugged in the new one and scanned channels all I got was PBS and a bunch of channels that I don’t care about. What gives? I didn’t touch my antenna at all and it picked up all of my channels just fine with the old Tablo.
SOLVED! Turn off built-in amplifier.
Welcome, @themalks.
The first thing I would check is if your antenna amplifier is on. The 4th gen Tablo has a built-in amplifier that may conflict with an external one. Even if you don’t use an external one, you can try changing the Tablo’s antenna amplification in the settings page of the app.
That worked! Thank you very much!!! I just turned off the built-in amplifier.
Perfect!
Glad I could help.
Not working for me. I only get one local channel. Move antenna?
A very good point was brought up here. A number of the complaints on this forum can probably be attributed to either too much signal amplification and or needing to be amplified. I bet a lot of people who bought the Tablo 4th gen do not have the knowledge about over the air TV signals and how it is impacted by the settings that are available.
I bet a lot of people don’t bother to understand that just because a station is listed as being tuned to it does not mean it is actually viewable or recordable as it may be very weak and it may come in some days and not others.
I’m not sure that’s a fair assessment (“do not have the knowledge”, “don’t bother to understand”), but your points about reception/amplification are very valid.
I had a great system that had to be completely overhauled when installing the Tablo. I do think that the 4th gen has a weak receiver and by turning on its own amplification, causes some network interference.
Each user’s circumstances are different. My Tablos needed wholly new antennas. The antennas have to be powered but the Tablo’s amplification has to be off.
It may be true that some are expecting a quick plug and play for reception, but I found the Tablo to be the most complicated to set up to receive stations that have usually come in great. A system that had worked for over 3 years without issue, split between two PVRs and a TV – without any amplifier – was both worrisome and frustrating to reconfigure.
Everyone’s case is different and some may need to adjust more than just the amp setting in the Tablo. It’s understandably discouraging. I’ve spent 3 months making my first Tablo run right, but many don’t want to go through that – shouldn’t have to go through that.
Usually, that quick setting is a fix-all for this problem. Checking reception maps is also very helpful (although sometimes out of date or doesn’t take into account elevation). Luckily, many new users live in areas where reception isn’t an issue.
Sadly, this dooms a user to hitting the Rescan button repeatedly just to find a decent antenna spot. @glenag711 asked about moving the antenna, and this will likely help. The problem comes when a fraction of an inch can throw off reception entirely.
Those setting up an antenna for the first time might find it beneficial to use a different device with a signal meter. Figure out which stations are the hardest to reign in (doing that little bit of extra research). Slight incremental changes in the placement/direction of your antenna are easier to see this way and once you hone in a spot with the best reception, continue the testing on your Tablo to see how all station are affected by running the channel scan to get an overview of them.
What can be listed as the strongest signal can certainly get muddled by the ones farther away as you try to find the perfect balance to receive all your local stations.
Based upon the complaints on this forum I am sure my assessment is 100% spot on.
I have one of my 2 Tablo 4th gens using the same antenna as my Amazon Recast. So I can compare both DVR’s and I see NO discernible tuner differences.
That’s where the whole “every user’s circumstance is different” comes into play.
Basically, what worked for me to get NBC local channel
(It did not show up in channel scan), despiteABC and
CBS appearing no problem…:
I have a leaf flat panel amplified antenna. Had to turn off
Tablo internal.amp , but leave the Leaf amp hooked up.
I’m having the same issue. I installed the unit in January and had only a couple minor issues, nothing to stop me using it. This week, it is no longer receiving the channels I had up until then.
I’ve tried reset, factory reset, moving the antenna (which came with the unit), turning amplification off and on, pulled the plug for 10 seconds (both from the wall and unit). I also looked into changing the Wi-Fi to 5G, but my app doesn’t have an Options or Edit Wi-Fi, and when I tap the Tablo’s name, nothing happens.
Have you tried rescanning for your channels?
One thing to try when you’re in there is to uncheck the channels, save your guide, wait for it to update, then rescan and add them back. But I would definitely try a rescan first, checking how well they come in with amp on and off.
Thanks for the reply. Yes, I’ve also tried checking and unchecking each time (not quite understanding what that is for). And with each attempt I’ve rescanned.
I did discover that the one station I’m most interested in is southwest of my house. I moved the antenna from a southeast window to southwest and was able to get three green dots (enough to receive).
Still, it puzzles me, and concerns me moving forward, as to why I would suddenly lose reception, and so significantly.
Initially, upon first setup and use, I could get all my locals, ABC, CBS, and NBC, full strength all digital 1030p, no problems whatsoever. 3 weeks ago I stopped getting ABC, rescanned and turned amplifier off in the settings, fine tuned my attic antenna, and still no ABC and CBS signal has now started to decay. I’m wondering if the Tablo internal electronics are starting to go bad and if so, can I return it for another?
That is odd.
Is it possible that, in the last three weeks, something new has cropped up outside that might interfere with TV signals? If you use an indoor antenna, is there anything that might be interfering with it inside?
This article may help: Where to Place and How to Install Your Over-the-Air TV Antenna – Tablo .
You can also reach out to our technical support team: https://tablotv.com/support/#contact . They should be able to assist.
Try connecting your antenna directly to your TV tuner and see what you get. That should help you determine if the problem is with the antenna or the Tablo.
I connected my antenna directly to my tv and got all local channels plus even some from a neighboring city.
I plugged into Tablo and got 1 channel. I turned off the Tablo amplifier and got the same poor result.
What gives?
It may still be a poor connection issue.
Unlike a single-tuner television, the signal from your TV antenna is split between two or four tuners in your Tablo. The device’s in-line amplifier does mitigate the signal loss but channels on the edge of visibility may fall off the ‘digital cliff’.
Moving your TV antenna to a higher location with better line-of-sight can help but switching to a more powerful antenna is a better bet.
