Clockwork!
I would like to try your app. My email is martin.bebow@gmail.com. Thanks.
Hi - thanks so much for inquiring. The folks here helped with some great testing, but now the app is done and available in the Play store. Itās totally free to try, so please have a go and see if it meets your needs!
Check https://play.google.com/store/apps/details?id=com.locobright.tablogo
Cheers!
@sctaylor Letās touch base in the new year so we can help you with some promo on this.
That would be an awesome way to kick off the new year! Will PM you in Jan. Thx!
Thanks @sctaylor for stopping by the blog to tell everyone about ota2go!
Please assist:
Does your app allow to change the download location to my microSD device?
These days memory directly on my phone is very tight but the 400GB microSD I have installed is where I store data for memory intensive apps.
Hi - yes, it sure should. I use my external card for this. The settings are simplified - if you go in to Settings and tap the location, it should let you pick internal or external storage.
Note that you canāt set the specific directory - just the storage device.
If you install the app and try before upgrading, you can be certain that it works on your particular device without any risk.
Let me know if you have any troubles!
Thx!
- Steve
Great to hear (whew⦠was worried because I was getting my hopes up).
Looking forward to buying your app when I get my Quad (hopefully it is in the next 30 days).
Awesome! Looking forward to having u on board
Make sure you give it a good thorough test drive to make sure it works for you before upgrading. That said, I havenāt actually had to refund anybody yet because it didnāt work, but happy to do so if needed!
Cheers!
Quick question: I have the Tablo Dual Lite with cloud storage (I do not have a physical storage drive connected), would this app still work, or would I need to invest in a hard drive? I would love the ability to download my recordings rather than stream them when Iām away from wifi.
Hi ā I believe so though I must say Iāve never personally tried it
The very best thing to do is grab the app (totally free) from the Google Play store and try it out. It will let you download 20 minutes of any recordings ā meant to be enough to validate that the app works well for you.
If that works, and if you like the app, then you can do the in-app-upgrade purchase to enable full length downloads.
If youād be so kind, can you please let me know how your experience goes? Would be great for others to be able to find here too!
Cheers!
- Steve
I downloaded the app, but I have had no luck with downloading anything that is recorded on my Tablo. I went into settings and checked to notify upon failure, and to notify upon completion - but I have not gotten any notifications. Iām not sure if Iām doing something wrong, but I go to the episode I want to download and click the download button. I get the spinning circle indicating itās busy, but it doesnāt ever download and I never get notified of a failure, and nothing ever appears in downloads.
Hi ā sorry to hear that, but thanks for letting me know! You should get a little message āanalyzing xyz showā, the episode should turn pink, and you should see (after a few moments) some progress counting 0-100% - and all of this should be reflected in an Android notification (the little notify icons at the top left). I take it none of this is happening for you?
Q: If you hit the play button instead of the download button, can you watch your recordings through ota2go?
Thanks!
So, when I hit play, it does play the episode.
When I click download, it turns pink, I get a small toast message at rhe bottom and then the episode turns pink and I get a spinning circle, but no other notifications it just keeps spinning. I left it for an hour last night and nothing.
I did record a video of whatās happening but I canāt upload it here to show you whatās going on. Iāll try to upload it to YouTube and link it when Iām off work.
Iāll add that Iām doing this at home, using the same wifi the Tablo is on.
Hereās the link to the screen recording I made:
Thanks for posting such great detail! A few quick Qās if you donāt mind:
- When you first watched the video, it used an external player. Did you configure that in the ota2go settings? If so, did it work with the internal player before you set that up?
- Do you know what firmware version is on your Tablo now (you can see in its settings page)
- I saw the toast message ātest: downloading 3 minsā ā did you ever see the āAnalyzing Will and Graceā message in similar format?
Thanks!
Actually, that recording I posted was the first time I ever tried to play the video. I just out of habit picked the video player I usually use. I should have opened up the settings on Ota in the video so you could see what things were set to. Iāll grab a screenshot in a bit and also try the default player.
Iāll look it up in a bit and let you know.
That is the only toast message Iāve seen. But I will keep an eye out in case I missed any others.
Thanks - can you let me know what phone model/OS youāre using as well?
