I have a Netgear Nighthawk RC7500 router. My ISP is a local regional phone company (VDSL using a bonded modem). I’m having problems getting Remote Access setup. I have tried the following:
- Set up two TCP Port Forwarding rules:
a. External Port 21121 to Internal Port 887 to the correct IP of my Tablo.
b. External Port 21120 to Internal Port 80 to the correct IP of my Tablo. - I have tried the following base on what someone else did:
a. Disabled Remote Access on the Tablo.
b. Disabled UPnP on the router.
c. Re-enabled UPnP on the router.
d. Re-enabled Remote Access on the Tablo (still says my router requires manual configuration).
e. To Add to this, the correct port forwarding does show up under UPnP after doing the above steps. However, I still cannot access my Tablo remotely.
Is the problem going to the modem perhaps blocking ports? The modem, according to my ISP, is setup in bridged mode, so everything should be getting funneled to my router.
Any suggestions are welcomed.
Thanks.
