I moved my tablo to the other side of the house and connected my tablo to my other router through ethernet. Now my Tablo Connect is broken and I can’t get it back. customer support is trying to help me but they want my routers port forwarding info. I’m logged into my router right now, a Trendnet, but I don’t see a port forwarding tab anywhere. Could it be called something else
Try looking here…
Advanced -> Firewall -> Virtual Server Rules
Awesome found it. It says “Virtual Server Function” and it’s disabled. I’m guessing you want me to enable it and put my info in.
Protocol: (TCP or UDP)
Public Port:
LAN IP Address:
Private Port:
Schedule:
Enabled:
What do I do with that?
Tell the support guy you’re working with what you just stated here.
