I have a Tablo Quad and it constantly stops recording during shows. We are not recording more than 2 shows at a time.
It also has jerky playback issues all the time.
The playback for recorded shows will stop the video, keep playing the audio, then when you hit the back button it goes all the way to the end of the show and starts from the beginning.
It will sometimes not even record shows at all.
My favorite is while you are watching live TV and it just reboots.
I have it connected via Ethernet directly to my network switch and all my devices are wired via Ethernet.
I am using the built in hard drive and I have a fan blowing on it because the previous 2 devices would burn your fingers if you didn’t.
I purchased this one about 3 months ago.
When I called support they said, we see no errors in the log, thanks for calling though.
This is the third and last device I will own if I can’t get this fixed.
I purchased one in 2015 and then again in 2022. And now I have the 4th gen quad.
The previous versions were a little more stable but did have reboot and record problems as well.
If anyone can help that would be great
