After I format my hardrive to use for Tablo. I took it off and try to use with my PC. My PC is unable to see my diskdrive but can see on windows drive manager. How can we reinstall the driver back to the disk so the PC can see it.
That’s because the Tablo has formatted the drive and the file system is now ext4. Windows does not support ext4 file systems by default. There are ext4 file system drivers for Windows if you really want to connect the drive to Windows. Google for the drivers.
However, you can’t use the HDD with the Tablo and PC simultaneously. The Tablo manages the drive and space on it, I do not recommend disconnecting and connecting it to your PC frequently.
