It seems like some people have an issue after the update. For me the guide works but only a couple of channels work when I click on them. All the channels worked before the update but now when you click on a channel it just opens but doesn’t load or say weak signal. Anyone have this issue?
I would try rescanning your channels.
I did the signal is slightly weaker for the channel I wanted to watch but usually a station that doesn’t work will say weak signal. Now nothing pops up.
Which Tablo app are you seeing this behaviour on? Does it happen on all the apps you’re using? Try rebooting the Tablo if you haven’t already. Don’t hesitate to send the details to our support team.
I use the Xbox to run Tablo
